Another emergency
Other Catalina 30 Tucson, AZ
Mates: This is for older catalina owners (early to mid 80's). It might apply to Catalina's in the 90's also but I'm not sure. A C30 friend of mine, who is monitoring this Forum, called me this morning to relate a situation that happened to him last week end coming back from Catalina Island. His steering broke about 10 miles off shore. A while back I had told him that it would be a good idea for him to try his emergancy tiller at the dock. I also told him that the nut holding the steering wheel can be a bear to get off. Why this is important is that you can't use the emergency tiller with the steering wheel in place. Do you think he took my advise!?! Read on to find out. When the steering let go, the first problem he had was finding the emergency tiller in the first place. The nut on the steering wheel proved to be impossable to get off and he did not have a wrench big enough anyway. He had to install the emergency tiller because the rudder was flopping all over the place but he could only move the tiller so far. The rest of the travel was blocked by the wheel so he ended up making big circles. His call for help was quickly answered by a power boater (god bless them most times - they usually have more tools than a sail boat), who had the wrench for the nut. The power boater had it off in seconds and would not take a dime for his work. He just hopped back on his boat and was off. So the moral of the story is check out the emergency tiller at the dock and break that steering wheel nut loose. Install it just a little past hand tight. That way you will not have any trouble getting it off.
Dave
Use The Sling Shot
On my 1990 Catalina 34, Catalina provided a wheel wrench. It's a wooden tool that looks like a sling shot minus the rubber band, etc. It's designed to remove the wheel nut without marring the chrome finish. I do agree with Don's advice. Always do a dress rehearsal of things that can go wrong at the dock. As Captain Ron said "If it's going to happen, it's going to happen out there".
Feb 12, 2004
85
- - Stingray Point, Va
Wheel Nut
If your nut is more than hand tight chances are you will need a puller to unstick the wheel from the shaft. After you get it unstuck, clean up both surfaces, apply some antisize, and reinstall. Removing the wheel may also be needed for some Autopilot emergencies (jammed belt). Don't ask how I know about this:(
Dec 3, 2003
2,101
I Can't Understand...
...why someone wasn't prepared for this type of incident. I know people who are the same way. An adjustable wrench will do the trick. Even if he kept a cheap set on board (one time use) it would help in this situation. Even charter boats provide a menial set of tools that can be used at times like this. *box
Jun 3, 2004
10
Catalina 34 S. Harpswell
Annual thing
One way to get regular practice at wheel removal and to keep things inspected, lubed, and tools available is in the annual decomissioning. When I lay up the boat for winter, I remove the wheel and store it below; it protects the wheel and me when I'm off-loading other gear, and use the opportunity to check out the condition of the hardware.
Catalina 320 Dana Point
I put one of the large knurled knobs on that
you can remove by hand, kinda pricey as I recall ($35?), unplug autopilot and remove. There's a lot of stuff that you got to get out of the way real quick for the emergency tiller & the wheel is first. What does annual de-comission mean? Does it have something to do with cold weather?
