Took the boat out yesterday for some new equipment shake down (radar, autopilot) and realized there was no water coming out of the exhaust. I have a “pee” set up on my boat that shoots raw water out the stearn to show the pump is working properly. I check this repeatedly and it was flowing strong so I know the engine was getting water but the exhaust was not.
Idled back to the slip and got into my manual. I found a clogged elbow that feeds raw water to the elbow from the HE. Problem fixed in 2 minutes. Back out for the shake down with no further issues.
Now my question. I want to remove the elbow for inspection. It is a inverses U type with typical difficult access. It appears to be more appropriate to remove the elbow at the 4 bolt mounting surface that attaches to the exhaust manifold than trying to get pipe wrenches in there. How common is it to be able to reuse the gasket? Is it a typical steel type exhaust gasket or a one and done type one? Opinion?
