Another ChartPlotter/Fishfinder Question
Ward H
Nov 7, 2011
3,843
Will a CP/Fish Finder read depths as shallow as 2 feet?
All literature talks about max depth. I found one reference to "as shallow as 10'". I talked to one store who said most fish finders read 5 to 10' min depth.
My Humminbird digital stand alone depth sounder reads down to 2' and since I have a shallow draft, I want to know if I am getting into water 3' or less.
Was wondering what you guys have seen on your CP/FFs?
May 28, 2015
280
Catalina 385 Atlantic Highlands, NJ
My Raymarine Fishfinder reads as low as 4.2 feet but since its 2 feet beneath the surface its lower limit appears to be 2.2 feet from the sounder.
Jan 7, 2015
77
Menger 19 Catboat Annapolis, MD
My older Humminbird GPS/depthsounder/fishfinder reads to less than 3', maybe 2'.
Jun 6, 2006
6,990
What kind of sail boat draws 2 feet of water????
You can just use your eyes to see the fish in water that shallow and surly the boat will spook them away in any case.
Jan 7, 2015
77
A Menger 19 catboat, that's what (actually, it draws 22" with the centerboard up). :)
Beachable, too.
I don't fish and don't use the fishfinder functions... the boat came equipped with the Humminbird from the previous owner. It does serve as a very primitive chartplotter, though.
If you think you can see fish 2' down in the Chesapeake, you haven't sailed here for a very long time.
Ward H
Nov 7, 2011
3,843
Bill, my O'day 25 draws 2' 4". Rudder extends below shoal draft keel about another 2 or 3". I set my low water alarm for 3.5' and the sounder is adjusted for true water depth.
I was out a couple of weeks ago when there was a blow out tide. I went out in 3.5', one of the few boats that could get out. Didn't realize it would drop another 1' while I was out.
I was able to push through 2.5' to get back into my slip but just barely.
I'm not fishing but if I am going to buy a chart plotter and if I can use the FF feature for depth, I will. (That was my first chart/plotter/fishfinder question and most said get the FF feature).
So I was talking to a vender who said they stop working under 5 to 10' of water. If a CP/FF doesn't read less than 5' it does me no good because I spend a lot of time in 4 to 5' of water. If it does read down to 2 to 3' then it works for me.
