Lots of Questions
Hi Jack,Well you have lots of questions and your concerns remind me of my early cruising days when I never slept well at anchor either. The good news is with experience you'll get much more comfortable at anchor, and it's a great way to sleep.In my opinion a single anchor properly set is very adequate for most situations. As you may know, this means a bottom with good holding, adequate swing room, proper scope, a good set, and an anchor of an appropriate size and type for your boat and the bottom. If you're nervous at anchor, consider upgrading your anchor and rode and using a kellet or sentinel. I have too large an anchor and also use a kellet. People are always making fun of me on this site for those facts, but I don't drag and I sleep well.If you are going to use two anchors, you need to have a good reason. If there is going to be a real blow and it will come from one direction, you could use two anchors set at 45 degree angles off the bow. If the wind is predicted to change direction overnight or you have a reversing tidal flow or you have a swing room contraint, a Bahamian Moor can be a good solution. To properly set a Bahamian Moor, you need twice as much rode on your primary anchor as your set will require because you need to set your primary anchor, back down to where you want to set your secondary anchor, and then pull yourself back to the middle. (See sailing texts such as Chapmans for details)It is extremely important if you set a second anchor that you consider your swing room situation. If everyone else has only one anchor down and you have two, they could swing to wind or tide overnight and you won't move much. That could result in an overnight collision. Obviously the first person in the anchorage sets the pattern for the anchorage. But even when we've been the first boat in the anchorage, we've had to point out our two anchor situation to others who miseed the fact and might have swung into us.Regards your gps, variablity in gps signals will make it appear you are moving a little even when you are dead still. Try setting your gps alarm some calm afternoon when your rode is hanging straight down. You'll be amazed at the apparent "movement" on the gps. Consequently to set the gps alarm too tight is to ensure a bad night's sleep, because the alarm will go off all night. Conversely if you set it too loose, you may drag aground or into another boat before your gps wakes you. Frankly, I haven't had much use for the gps alarm.My recommendation: Buy high quality, oversize ground tackle, set a single anchor well with plenty of scope, and get a good night's sleep. Use the second anchor only for special situations.Hope this helps.Gary WyngardenS/V Wanderlust h37.5
