Ok..just got back from HI and met up with the Beta tech. He installed the new saildrive top plate and shims per Twin Disc service bulletin. Why didn’t my new saildrive have all the bulletins incorporated before shipment?..Anyway, started the engine and after 5minutes, it started puking oil out the vent again. I had a very pointed conversation with Beta West today. I indicated I was very close to demanding a new saildrive. And, it might be Volvo or something..Since it was made in Italy, I may have to wait a few days to see what they say. Also the engine did not want to start again. The tech spent a little time and noted the return line doesn’t definately go below the bottom of the tank which I know. It is very close..Its impossible to do unless I put a longer loop in and drape it into the bilge. He has run into this before and he is thinking about a very weak check valve in the return line. He also said the on board fuel filter can get hard to bleed. I think I will just change it since I’ve never had it off. (Only 85hrs on the engine)..First priority is the saildrive..
