Hello all
Here is another question about my mast, while out on the bay yesterday I met another sailor and we decided to anchor and tied up the boats together, what I did not notice right away is that he had attached one of the docking lines to my outer shroud, that is I did not notice until a power boat went by and the boats started to roll which caused the docking line to pull hard on the shroud (that was when I noticed it and removed it). I then looked up and noticed that there was a little dent on the mast about a third of the way between the spreaders and the top of the mast, the dent appears to be about 2" wide although not very deep, almost as if it was hit with something....I am not sure if the dent was caused by the shroud being pulled hard a few times or if the dent was there before and was not noticed...is it possible to dent the mast at that point by pulling the shrouds and how concerned should I be? (I will post some pics soon)
