Anodes for AC sytem Hunter 44DS
Jul 25, 2013
5
Hunter 44DS St Petersburg
I have replaced my AC units with a different brand (Marinaire) and used existing wiring. They have an added need that I am unsure how to address. They want the unit connect to anodes to reduce corrosion. On my Hunter 44, the only anode I know of are the zincs. In order to wire this, I need something else, I am sure. Thoughts, knowledge, or suggestions appreciated.
colemj
Jul 13, 2004
774
This is to prevent any potential galvanic corrosion of the A/C when plugged into shore power when another boat near you has a leaking electrical issue and you share a common ground through the shore power. IMO, this is a rare occurrence and you will notice the problem through other means like your engine or prop shaft anodes disappearing before the A/C experiences any issues. You could bond the A/C to your engine block to use that anode, but personally I'd install a galvanic isolator on the shore power ground wire and prevent the problem from ever reaching your boat in the first place.
Mark
JamesG161
Feb 14, 2014
7,912
Hunter 430 Waveland, MS
I asked Dometic the same question.
On my boat bonding is not needed.
Simple test:
1) Disconnect from Shore Power.
2) Use DVM to check low resistance between Copper Dometic Cooler/Evaporator and Engine.
Low resistance = Electrically connected to Engine shaft Zinc.;)
Shaft Zinc is protecting your AC.
Jim...
