Annual maintenance
Stuart
Hi Peggy, Some time ago, you mentioned changing some of the parts for the head on an annual basis. Is there a "kit" that includes these parts, or could you tell us which ones to replace every so often? Have a standard head on a 1999 Hunter 340. Everything is ok, but the pump is getting a bit sticky, and we want to stay ahead of any potential problems. Thanks
P
Peggie Hall/HeadMistress
Time to lubricate the pump
In fact, it's prob'ly past time to do it as preventive maintenance. So, buy a tube of Super Lube, lube the pump replace the joker valve...and you should be ok till next year when you need to do it again. You might want to check out the link below, too.
Stuart
Does your book have diagrams?
I find it helpful to see diagrams instead of just reading about what to do, curious if your book has diagrams for instruction? Thanks, Stuart
