ANL Fuses, $3
11,760
While inexpensive they do not meet the ignition protection marine standard.. You can find all sorts of cheap ANL fuses but the only brand I know of that passes the IP standard are the Blue Sea ANL's. Also some cheap ANL's are actually built to the ANN standard, they share the same foot print/fuse body. ANN fuses are a fast blow and not suitable for motor start up loads...
