Well
Mainesail, if you want to run down their tests, I suggest you pay for the original article, and compare their total test process to your ideas.
David I do have a paid subscription and have both articles sitting right here on my desk. It's where I got the quotes and specifics from..
We have a well known tendency to love the boat, or gear we have. A lot of these discussions reflect preferences based on that subjective emotion, not on balanced analysis or testing. Of course, the product stories of our suppliers provide lots of ammo for us.
I have done lots of my own testing using my own anchors. I don't consider my many years of anchoring subjective. I knew bottom type, scope, water depth and how each anchor was set and that is not subjective that is actual data. If they dragged or refused to re-set I consider that data based on the conditions, scope and such not a subjective opinion.
I own and have owned Bruce, CQR's, Fortress, Danforth, Delta, Super Max, Spade (both an aluminum and steel version), Manson Supreme & Rocna. My own testing & use, in Northern New England, has lead me to the newer generation anchors like Spade, Manson Supreme & Rocna. Contrary to popular belief Maine has some nasty bottom types and it's not all mud it is, and can be, a good proving ground for anchors.
I also own a Super Max, which is also a new generation anchor, and I am not impressed with it at all so my "subjectivity" is not simply new vs. old but rather what works well where I choose to anchor and what does not. If the Super Max was all it was cracked up to be I'd still be using it and would have never purchased other new gen anchors. A funny thing is that I actually own two identically sized Spade's an A-80 (made of aluminum) and an S-80 (made of steel). The A-80 is a poor setter in hard bottoms and the S-80 does significantly better? In one location I tried to set my Spade A-80 six times and it would just skip across the bottom. I dug out the steel version, remember same physical dimensions the only difference is weight, assembled it and it set in about 15 feet as hard as being tied off to a pier..
If my older gen anchors, and my Spade A-80 and Super Max had been more reliable I would have never spent my hard earned money searching for a better mouse trap. As I have said before, many times, my Bruce anchors were the best setting of my older generation anchors. Unfortunately I never slept well when it blew because I knew the holding power was more limited than other anchors. As I have said before the Bruce is a fine anchor but should be up sized at least one size over the suggested size. Practical Sailor states, NOT JUST ME, it should be up size one or TWO sizes. Beth Leonard and Evans Starzinger go up THREE whole sizes on Hawk..!!
Here's some of the testing I've done on my own for my own curiosity:
Manson Setting Charecteristics Video (LINK)
Spade Setting Characterisitcs Video (LINK)
Practical Sailor used to be a very good publication. I agree with others that it has become somewhat less in-depth and their methodology can often be quite odd. I still subscribe, but every time I read an article like the Answers For Hard Bottoms (vol 34 no 11) & Heavyweight Field Tests (vol 34 no 12) it makes me wonder why I continue to subscribe..
I am planning on spending almost $750.00 of my own money this spring on a strain gauge. Yes, I like real data of which there really has been very little that I really trust! I'm fairly fed up with this lack of good data so I will use it for a number of things including testing holding power of the different anchors I own all in the same substrate so it is a fair comparison. I will also measure the thrust of my engine and the effects and loads generated by wind/windage on a 36 foot sloop something I have NEVER seen recorded with a strain gauge. All windage data I have been able to find is theoretical not actual. It will be nice to finally know how much pull my anchor or mooring tackle sees in 30, 35 or 40+ knots..
In short I have done lots of testing. When I got my first Manson Supreme, the one Tim R. is currently using, I spent two full hours setting and re-setting it in an area where I know many of my anchors, including two of my new gen anchors, won't set at all or every sixth try at best. I could not get the Manson Supreme to not set no matter how much I tried. Needless to say I was impressed and Manson had ZERO marketing at the time, no ads, no web site marketing and no equivalent to Craig Smith, so I was NOT swayed by;
"the product stories of our suppliers provide lots of ammo for us."
Yes I take anchoring seriously, maybe too seriously,
but having been dragged into, sustaining damage, and having helped to pull many boats off the rocks over the years after storms I think I have decent reason to take it as seriously as I do. Many have used CQR's & Bruce's successfully for many years, I did too, and my CQR has the rust and scars to prove it. Unfortunately for the pristine areas we like to poke into it was anything but a good setter for me. I'm not one who likes to sail past a beautiful area thinking; "I'd like to stay there but the holding sucks", so I keep searching for the anchor that will let me stay there...
There are many boaters who have bottom conditions that will likely never need anything more than a CQR or claw type anchor but some of us don't have the luxury of great holding bottoms everywhere we want to anchor...
Finally, I was simply trying to add my two cents, and some solid conclusions from a respected organization. I'm sorry that it inspired an unexpected response.
David please keep adding your two cents that is what this board is all about!!
All I was doing was pointing out the idiosyncrasies and reasons why one can't always take Practical Sailor statements at face value. Often they are spot on but sometimes they do miss the mark. I really don't get this test at all and feel it was more of an embarrassment to their testing methodology/credibility than anything else.
Anyone who peruses the sailing forums knows Beth & Evans use a HUGE 110 pound Bruce anchor but their anchor is way up-sized compared to what is recommended, three full sizes up sized. In light of that it's no surprise why they have had such good success with it and
"never a drag, ever". The recommended size for their 47 footer is a 55lb but they go three extra whole sizes up to 110 pounds..
If you did what Beth and Evans do on their boat, on your Hunter 27, that would leave you a 77 pound Bruce anchor.....you'd never, ever drag either..
