Chain length for 5 to 1 scope
First, decide where the dock is going to be located. Then check the water depth at that location. If the anchor chain is going to be attached to the deck of the dock, add the height of the deck above water to get the effective depth. Multiply by 5 (or whatever scope you finally decide on) to get the (horizontal) distance.Assuming the water isn't that deep, set a stake in the lake (a piece of 1-inch PVC pipe should be OK). Tie the end of a light line that's a little longer than the required horizontal distance to the PVC pipe. Make sure it won't slip down. Row away from the stake until you're at the end of the line. Mark the spot.The length of chain you'll need is 5.1 (square root of 26) times the effective depth. Your scope will be a little more than 5 to 1, but you're probably better off with more scope than less. If you want exactly 5 to 1, the horizontal distance would be 4.9 (square root of 24) times the effective depth.One last comment. Since you're setting chain and scope, why not use regular anchors that hook into the bottom instead of concrete blocks. They certainly would be easier to set than a huge block of concrete. In addition, the concrete loses about 40% of its weight due to buoyancy once submerged. The resistance to movement of a concrete block depends on its submerged weight. A regular anchor should offer significantly more resistance to pull. Good luck.PeterH23 "Raven"
