Setting you anchor
This works for me. After you lower the anchor to the bottom, snub it up and drag it a foot or two to get it pointing in the right direction. Then as the boat drifts back let out your rhode. keep a little tension on it so it does not wind up in a pile on the bottom. When you get to the proper scope, secure the rhode. Put the boat in reverse and just as the rhode gets tight, put it in neutral, which will put a slight tug on the anchor. Repeat this proceedure several times, which will cause the anchor to dig in. Next, go into reverse idle and put a little more strain on the rhode. Check all the while that you are not dragging. Lastly, once you are convinced that you are set, go into reverse once again, and when the rhode gets tight, back down on it about 1500 to 2000rpm. Go to this speed gradually, you do not want to suddenly jerk the anchor out. If you can back down at high rpm, chances are you are set well. Now relax and observe. If you are in, the only thing that could dislodge you is a wind shift, or high winds. Good luck!
