My apologies and A Clarification
Of course, Fred is “right” (in the “practical” sense) - but Denise asked for a “formulae”.Obviously, I was ambiguous in my explanation. Sorry.1. Not all boats have a windlass - even those with all-chain anchor rodes.2. When a windlass is installed, the gypsy is NEVER used to secure the chain (carry the anchor load). Chain anchor rodes should be secured to a “chain stopper”. (Ie: http://www.sailnet.com/store/item.cfm?pid=14183 )Thus, the anchor load should never be on the windlass gypsy (bridle or not) !!!3. The purpose of an anchor “bridle” is to absorb the shock that occurs when an inelastic chain anchor rode is lifted taut under high loading. This shock would be transmitted to both the boat (deck hardware) and to the anchor (perhaps, pulling it loose). 4. A more elastic (stretchier) bridle, of smaller diameter & strength, will offer greater protection from these shock loads than will a larger diameter & stronger bridle.5. Under ultimate conditions, this stretchier (but weaker) bridle could break. The bridle has much less breaking-strength than the properly sized chain. If the bridle should break (long before the chain is overloaded), it will provide an obvious and dramatic “alarm” that things are getting out of hand. In this extreme case, the chain is not likely to break (as Fred points out) - but something might let go - the anchor, the deck hardware, etc.To rephrase Fred’s good advice:Make certain the chain is NOT secured (belayed) to the windlass, but to a purpose-made deck fitting, such as a “Chain Ctopper”.Attach a “Bridle” so that there is “some” slack in the chain (between the stopper and the chain claw). I recommend that “some” slack be quantified at between 20% & 40% depending upon the composition of the bridle rope) of the slacked chain. By formulae:Bridle (or Snubber) Rope Length = distance from chain stopper to bridle attachment @ chain x 1.2 (to 1.4)
