Anchor
14
Catalina 25 Lake Travis
Can you have too much anchor? A friend gave me a 20lb danfourth and was reading that's for about a 50 ft boat.
Nov 6, 2006
10,253
Probably bigger than would be "recommended" for your boat.. but the limits are handling it and finding space to put it.. If you are comfortable handling it and have a place to put it on board, there is no problem with using it.
Jun 9, 2008
1,857
- -- -Bayfield
It is a good idea to have a few anchors on board. One size can be a general working anchor. Another would be a storm anchor (the big one) and another just a lunch hook (like 4# or 8# for a 25' sailboat). It's a good idea to have a 2nd anchor on board if you lose one too.
May 13, 2013
29
Tayana 48DS Phoenix, AZ
Up to the point you can't handle it, or it weighs your boat down excessively, there is no such thing as "too much anchor", particularly on a stormy evening..:D
A 20 lb Danforth would be about right for a 35-footer, so it would be extra-secure with your 25. But if you get involved with raft-ups and the like, it would be a really nice thing to have! if you use it, make sure you set it well.
Hartley
S/V Atsa
Sep 5, 2007
689
MacGregor 26X Rochester
Danforth's site shows the high tensile good for a 50 footer in 20 mph winds. That's a far cry from a 50 or 60 mph blow. Given the fluke anchor's propensity to not reset if it gets pryed or pulled loose, I woudn't consider it overkill for an oh-crap storm anchor for your boat. I keep a similar monster on my little boat, with chain and rope rode, ready to go but stored so it doesn't get in the way. Just in case.
http://www.danforthanchors.com/hitensile.html
Ross
Jun 15, 2004
14,693
Twenty pounds is not a very large anchor for any craft over twenty feet. I weigh 160 pounds and all of my ladders are class #1 commercial grade rated for 300 pounds. The difference in the feelings of safety are wonderful. With a 20 pound danforth and some chain you should be able to sleep well on a 7:1 scope.
Mar 6, 2013
14
Thanks. The hard part will be seeing if I have enough room to mount that monster up front and out of the way. It's huge.
Mar 6, 2013
14
I have about 30' of chain and 300' of line. Deepest I've read on my depth finder in Lake Travis has been about 180', but it shallows out real fast. Droughts been killing the lake.
Sep 5, 2007
689
Can you store it below somewhere? Keep the working anchor in the normal (for your boat, which I think has an anchor locker) location, ready to deploy, but put the big one some place out of the way, where it wouldn't take too long to get if needed, but such that you're not tripping over it all the time.
Mar 1, 2012
2,182
I have a friend who, when asked how large an anchor always says-
" five pounds less than the heaviest you can lift off the bottom"
Bit of an exaggeration, but ---
On the other hand, a 20 pound Danforth is a monstrous big thing to stow. I just sold two of them and it's just a huge anchor- Had them left over from a 35 footer.
I use a 22 pound Bruce with 100 feet of chain (plus nylon) on my 25 footer, which has worked well over some 10,000 miles of coastal cruising. And I carry a 12 pound Hi Tensile Danforth as a backup. Plus a 15 pound Folding Northill. With separate rodes for each.
If you go traveling, take at least two, and make 'em different kinds. Then if one won't work in a particular bottom, another just might. Besides, SOMETIMES you need a Bahama Moor:)
capta
Jun 4, 2009
5,103
I use an 88# anchor on our 53' ketch with 300' of chain. 20# isn't even a lunch hook. Should be OK for you, though.
Mar 1, 2012
2,182
I guess 20# wouldn't be.
30 years ago, I used to crew on a 50 foot on deck schooner. She catted a pair of 100 pound fishermen on 1/2 inch chain. Manual windlass.
After getting underway from a Bahama moor, you were READY for Breakfast!!
Mar 6, 2013
14
The working anchor is mounted on the bow stern with chain and line in the anchor locker up front Was thinking I would switch them out use the smaller one as the extra.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
James, I sail a 23' San Juan on a fresh water lake that has many anchoring areas where the depth is from 10 to 20 feet deep. I also use a Danforth anchor of 16#'s. It has held in winds of 20 mph without a hint of slipage. I use 20 feet of 5/16 chain and 150 feet of 1/2 nylon with a scope of 7 to 1. You must be able to back the anchor down very strongly or it won't hold a dingy. I honestly think that a 20# anchor is too large to back down with a boat your size. Go try out the anchor and dive on it to see how it buries itself. If she is dug in great, if not then drop a size and try again.
Good luck, Ray
