See the solution below from Scott (Archives)
I am planning on making this change. I just replaced my 25' chain with 150' + 150' 9/16 nylon. Nice to have the extra chain in the S.Cal crowded anchorages where I can get by wth shorter scope if needed.See below for Scott's (from San Diego) fix taking from Archives:Modify the Hawsepipe There are some posts in the archives about how to re-run the hawse pipe so that it will drop the rode into the center of the anchor locker instead of the "V" of the bow. This solves the problem. I simplified the install a bit by buying waste pipe (4" diameter) from Home Depot with two 30 degree pipe angles. Pull out the vertical board in the front of the v-berth and then fit the new hawsepipe in. You will have a vertical straight piece from the deck to the first angle piece, another straight piece heading aft through where the board was to the second angle resting on top of the anchor locker inspection hatch in the v-berth. Mark where the angle piece rests on the inspection/access hatch in the v-berth and cut a 4" hole there. Then insert one very short straight piece vertically in the 2nd angle through the new hole. This short vertical piece will go in the hole you just cut and hold the new hawsepipe in place without any glue, nails etc... You want it inserted into the inspection hatch, not glued, so you can still lift the hatch when all done. Not anchoring it to the hatch leaves enough room to pick up the hatch and slide it to the side when you need to reach into the anchor locker (not very often anymore). Finally the hard part. Cut the vertical board (plywood and white cover) from the front of the v-berth horizontally aligned with the center of the middle straight piece of pipe. Then cut out the two complex semi-circles (actually half ovals). Insert the wood above and below, add some teak trim over the cuts and you are done. The only significant change from the previous posts in the archives (with photos) is that instead of kerfing (sp?) a straight pipe to get it to bend at the right angles, I used the 30 degree angle pieces. 100' or more of chain is no longer an issue since it drops into the center of the anchor locker. I don't normally keep that much weight in the bow, but can when planning a trip where I know I will need it. The only caution left is to make sure the three strand doesn't bunch up going down the pipe because of curling in the line. I just pay attention to make sure it is falling free. A short tug from top side (6" or so) then let it fall again is enough to keep it going into the locker. All chain rode is heavy enough that there is no problem at all. Plait is another option that should work with no real issue, since it won't be stiff like the 3-strand. The solution is actually very cheap. A few bucks for the teak trim/moulding wood and a few dollars for the black plastic pipe. It does protrude a bit into the middle of the v-berth, but no significant impact on the sleeping comfort. The whole project took about 8 hours, since I was learning and designing as I went. ||||||||Enjoy,Scott
