Have you tried rigging a bridle to pull the rode inline with the hull and point the boat dead into the wind?
Just throwing this out there...
We have our anchor sail tied so that it is off set from the centerline like Sailrite suggested in the instructions. Set like that it actually sails the boat off in one direction and pretty much holds it there, kind of like heaving too. It works. Does it stop all swing and all movement? No and I don't think anything will since the conditions are constantly changing. I often take the wind gauge up to check wind speeds and they are never constant even if they kind of feel constant to me. I'm sure there are always constant slight changes in direction also that we don't pick up on unless we are looking up at the windex.....FYI, thinking about the anchor sail a little more - I think it likely is lift that aids the stability and not the drag. You can see in the attached drawing that the lift of the anchor sail is going to try and rotate the rear of the boat such that it lines up with the wind..
Incredibly large mass or.. SSL (sleeping sea lion)
ie, jib sail bag - when I douse the hank on jib - which I can do single handed very easy from the cockpit - I just wrap the "ILM" bag around the jib where it lays on the deck.. my jib actually has battens so also no folding. When I trailer for short distances (like less than a few miles), the ILM just stays on the deck with jib inside, set up is very fast the next use.
Regarding the anchor and mooring, I remembered this post http://forums.macgregor.sailboatowners.com/showthread.php?p=843086#post843086
Since I’m on a mooring a lot more than on anchor (at least at the moment - things change every year on how I use this very versatile boat), I guess Ill leave the anchor where its out of the way..
Seriously off topic.. just some guy, where do you guys from Tucson sail?
How about Lake Pleasant???Patagonia- 260 acres.
Roosevelt- 13,058 acres
Havasu (19,300) looks pretty good. Now that my trailer is somewhat safer, I just may check that lake out. Thanks.
