Anchor Rode for Southeast Alaska
Feb 8, 2021
2
Cal 29 Juneau
I’m looking for Anchor rode recommendations for our Cal 29. I’d like to hear what people are using on similar sized boats. I’ve spent a fair amount of time searching posts, reading ground tackle charts, etc.
A little background. New to sailing this last summer. Based in Juneau Alaska. The boat currently doesn’t have a windlass and came with 15’ of 3/8 chain and 150’ of 1/2” and a 22lb Rocna. After our first week of cruising I quickly realized that wasn’t enough. So I hastily bought 30’ of 1/4 HT & 250’ of 1/2” 3 strand. After a few more weeks of using this set up I’m still looking to upgrade most likely with an electric windlass. The average depth that I’ve been dropping the hook is 30 - 80’. Since I’m new to this whole anchoring thing I’ve been a little nervous getting to shallow. Generally I’ve been following The Coast pilot and Navionics recommended depths and known locations. There are a few coves on the chart with even deeper anchorages and I’d like to eventually have enough ground tackle to check them out.
It sounds like all chain is pretty popular with world cruisers. Definitely don’t plan on cruising outside of SE Alaska or getting too far from land in our Cal 29. It sounds like one major advantage is chafe protection against corral. Don’t think we much of that going on up here, but potentially sharp rocky bottoms?
This is what I’m considering, what do you guys think? Should I go bigger on any of the aspects? Obviously as I price out components for a bigger setup it starts getting pretty spendy
( Welcome to Boat ownership I guess!)
1. Electric windlass- Anchorlift Barracuda 900 or Maxwell RC6, or other similar entry level windlass
2.Chain 100 ft of 1/4” HT
3. Rope 600ft of 1/2” 8 plait
4. Rope chain spliced together with a 5/16 shackle at the anchor end
Should I consider a swivel instead of Shackle? Should I look into an oversized welded link on the end to accommodate a larger shackle?
The other choices I’ve contemplated are obviously upsizing all of the above to 5/16” chain and 5/8 rope, and heavier duty windlass.
Also, I’ve thought about a manual windlass for cost and simplicity
Thanks in advance!
May 25, 2012
4,338
how do you plan stowing all this weight and bulk? proper load management is a consideration you do not mention.
will all this weight be stowed below the waterline? will all this weight be stowed in the middle of the vessel. how many new batteries will this require to power? 600' of line. will you need a drum to wind this on so it does not tangle?
the boat came with what most would use on a 29' boat here on the great lakes. we don't need the chain up here. just dead weight to carry. no coral here.
all captains want to sleep at anchor. i get it. so many things to consider.
keep your load low!
May 25, 2012
4,338
all weight loaded above the waterline makes the boat more tender/tippy. makes for reefing more often and earlier. the ride suffers as well.
Jun 14, 2010
2,408
+1. .. and the bow is the least buoyant. Ideal place for weight is low and centered, not in the ends. 600’ of wet nylon is not light.
IMHO with a 30’ moderate displacement boat, you should minimize chain and rode. I‘m not familiar with the Alaska coast, but 30-80’ is pretty deep. If you can find shallow anchorages you’ll have better holding, but you need adequate swinging room in the radius from where you place your anchor. (If the anchorage is protected you don’t need much water under your keel).
Likes: jon hansen
dLj
Mar 23, 2017
4,759
I can't answer your question without doing some homework. What are your tidal shifts up there? On your charts, what is the range of anchorage depths where yo uwill be going. Definitely 30 to 80 feet are deep anchorages - but I don't know what you have for sloping shorlines where you will be going. I know that the coast of Norway will have very deep anchorages and the slope of the shoreline is such that you can't have enough scope out for a good anchorage and that often what is done there is running very long lines to shore and then dropping a long anchor. That way you don't swing as you typically do off just the anchor. I don't know what's normally done in your area. I'd suggest you talk to other sailors in your area to find local knowledge on preferred anchoring techniques.
Given what you have said, I think I'd be more inclined to have something like 4 lengths of say 25 foot chain, keeping one of them with the anchor and being able to distribute the others in locations better suited for weight distribution and pull out lengths as needed for a speicific anchorage.
600 feet of rode - you'll need a roller to handle that effectively. I guy I know sailing in Norway that carries a horizontal roller that he puts in the back of his boat and that rode length (I think he carries about 1000 feet) is used to tie off to shore so his boat doesn't swing from his bow anchor.
As others have said, if you can anchor in less depth. That would be preferred.
dj
I have no firsthand experience sailing in Alaska but I understand they do have very drastic tidal ranges.
You may need 40+ feet under your keel if you drop the hook at high tide.... and you may need to pay our a lot of rode if you drop the hook at low tide.
Likes: jon hansen
Dec 25, 2000
5,950
Over the years of anchoring in PNW waters I've use some basic rues of thumb with successful results.
1. Tide tables provide important information about ranges so keep informed before setting out.
2. Depending upon the selected anchorage, most will offer good conditions with mostly mud/sand bottom.
3. Mid tide, a depth of 20'-30' offers a dependable set with ample swing room.
4. Our 35,000 pound boat is equipped with a 40 pound Danforth anchor, 50' G4 5/16" chain and 150' of three strand nylon rope and a 20 pound lead kellet.
5. In normal conditions I'll pay out 110' of rode and increase to 140' if sour weather is in the forecast.
capta
Jun 4, 2009
5,006
One of the problems with anchoring in very deep or extremely cold water you can't see the bottom in, is that you can expect to lose your gear periodically. A lot of anchorages are rocky.
I'd be asking this question to the commercial fishermen in your area. There are a lot more of them than sailboats up that way.
dLj
Mar 23, 2017
4,759
Bay of Fundy is quite a long way from Alaska. It's between New Brunswick/Prince Edwards Island on the East coast of North America.
But, what the tides are where the OP is asking about I don't know.
I used to sail in a region where there were consistently tides in the 9 meter range (About 30 feet range) and there are tricks to anchoring with that kind of tidal change for sure...
dj
p.s. OK, I just read the WHOLE article you posted, and the tides in Alaska are referenced as the highest in the US...:facepalm:
Likes: rgranger
capta
Jun 4, 2009
5,006
I'm from the Bay area where tides run about 6 to 8 feet, but after 5.5 years in the tropics, I'd kind of forgotten the whole unpleasant mess.
Anchored in the river at Bundaberg, Oz, 11 miles inland, water level wasn't much determined by tide, as I recall. Off we pop to Rockhampton and secure the dink to the wharf with what I thought should be plenty of line for a tide fall or rise. Well.........not exactly!
When we returned, the dink was hanging by her bow line, the motor about 8' from the water and the bow another 8' below where I stood. "Danger, Will Robinson!" "Danger."
  • Wow
Likes: rgranger
We regulary get a 6' swing here, sometimes more. My work place has a very nice boathouse with slips etc. But at low tide it is often mud. So... you have to time it. I wish they would dredge. I'd love to commute to work by boat. :biggrin:
Why NEW GEN Anchors are Better:
Anchors & TEST Results of New Generation Anchors EXCELLENT & Important
Anchor System Sizing Tables (Reply #6) & Swivels Ground Tackle & Anchor System Sizing TABLES & Swivels
Steve’s Anchoring 101
The Rocna. All 20kg of it with 100ft of chain. The rest of the world can debate all they like. When I pull into a place like Bodega Bay at midnight and the fog is so thick I can't see the jetty 50 feet away to make an entrance, I drop my hook in the rolling ocean swells with the surf crashing (Foster says it's like staying in a cheap Best Western beside the highway), and I sleep. And in the morning I have a windlass to pull the beast up and I wouldn't trade it for anything. (I also wouldn't add more chain - this works perfectly in 25 to 30 feet of water - you let all the chain out and you tie off nylon at the preferred scope and don't bother with snubbers and chain hooks and all that stuff...)
You are cruising and anchoring in Alaska not the Caribbean.
My way to analyze the challenge.
You need to consider the local conditions that you expect to sail in and then add a safety factor.
Do you expect to be regularly caught out in a 100ft deep (16 fathoms) bay over night in plus 50 knot winds?
If so based on your boat size and displacement weight you need an anchor one size bigger say a 35lbs Mantus or Rocna than one designed more for your boat like the 22 lb anchor you possess. Your anchor is geared for your size of boat in normal cruising conditions. Anchoring in less than 50 knot winds. I note that much of the bottom in the bays and inlets is listed a Mud or Sand/Mud. Best bottom to have for setting an anchor.
Now if your out on the water, and such adverse conditions surprise you, you are not getting any sleep. Your throwing out the anchor you have and siting in the cockpit with the engine running prepared to go to sea should the anchor start to drag. Your not looking too get anywhere just maintain your boat in the safest waters possible till the storm passes. You can do a lot to relieve the strain on the anchor if you take a little of the stress off the anchor system by powering into the storm at low RPM "Holding Station" at anchor.
Having 100 ft of chain and a 35lb anchor down 16 fathoms is a lot of weight to haul to the surface. I am sure you are young and capable, but you will be wearing out your back in no time. That is why if doing this manually you will want mostly rode and maybe 30 ft of chain. 200 ft of "rode" (rope). Nylon being the preferred material as it gives (stretches) absorbing the pull and strain meaning easier on the anchor and the boat.
  • 3 strand twisted nylon will be least expensive. It tends to get twisted and not always lying flat.
  • Nylon Brait combines braiding technology with plaited rope
  • Double braid construction - nylon cover, nylon core
On my 35 ft 17000 lb displacement boat, I opted for 250 ft of Nylon Brait rode spliced onto my 100 ft of chain. Having installed an electric windlass and the powered system to run the windlass (which cost almost as much as the windlass) I have a 35lb Mantus anchor sized for my boat on the bow. This anchor system weighs in at about 145 lbs.
I have a 33 lb Bruce with chain and rode I can carry stowed near the keel. I will load a coil of 600 ft light line that will allow me to reach out and tie to a rock ashore when cruising north on the inside passage.
This also means you need to be careful in selecting your places to stop.
Here is a link to an aide. It is not everything but it can give you good info to help select the best anchorages available. DeepZoom Nautical Charts Tides and Currents
Slide the map up to your location. You'll get a NOAA chart of the area. The depths are in fathoms. Aprox 6ft to a fathom. With the wind in the right direction Sunny Cove in Taku Bay (apron 18nm from Juneau) looks like it could offer a nice overnight anchorage.
capta
Jun 4, 2009
5,006
Got a friend with a Mako or something that has a couple of good, big outboards on the back? Have him bring his boat in an hour after high tide and run his engines as the tide drops and he'll blow the mud out of the slips and it will float away on the ebb tide.
If you need more, then bring in a bigger boat and do the same until your slip is clear.
:laugh:
I thought about putting out a small anchor and dragging it under power each time I leave the slip... but your way sounds like a lot more fun.
Maybe your friend could drag a big anchor......:poop:
  • Ha
PaulK
Dec 1, 2009
1,446
Sabre 402 Southport, CT
Hi Patrick
My brother's been sailing out of Juneau on his J/30 for a long time. He sailed it up there from Seattle to start with. He cruises regularly up to Tracy Arm and goes around Admiralty Island, so is bound to have ideas about what works up there. He does not have a windlass. He suggests you join Southeast Alaska Sailing. I will pm you his phone number; he's expecting your call.
Feb 8, 2021
2
Cal 29 Juneau
Thanks everyone for the intell. Definitely been fun learning about all the different aspects of sailing, there’s a lot to think about.
Still would like to hear more opinions about the “nuts and bolts” of the set-up I’m contemplating purchasing for our cal 29 (8,000 lbs)
maxwell RC 6 or equivalent
100’ 1/4’ g4
Several hundred feet of 1/2” 8 plait
22lb Rocna
Does anyone have a similar setup for a similar size boat?
dLj
Mar 23, 2017
4,759
100’ 1/4’ g4
22lb Rocna
It depends upon how you are sailing. Are you going out for weekends, and potentially the occasional weeks vacation? Or will you take longer trips where you are sailing for several weeks at a time?
In the first case, the above doesn't look too bad. In the second case, I think I'd up the chain to 5/16". I think in both cases I'd want at least a second anchor. I carry 3 anchors on my current boat.
If you don't have problems with chafe on your anchor where you are sailing, I'd likely go with less chain and more rode. Lets see, 100 feet of 1/4" is about 63 pounds. 50 feet of 5/16" is about 47 pounds.
My inclination would be 50 feet of 5/16" chain, and then the rode I'd need for where I'm anchoring.
As far as the RC 6, I don't have first hand knowledge, but have heard those are nice winches.
All the above is worth exactly what you've paid for it...
dj
