I’m looking for Anchor rode recommendations for our Cal 29. I’d like to hear what people are using on similar sized boats. I’ve spent a fair amount of time searching posts, reading ground tackle charts, etc.
A little background. New to sailing this last summer. Based in Juneau Alaska. The boat currently doesn’t have a windlass and came with 15’ of 3/8 chain and 150’ of 1/2” and a 22lb Rocna. After our first week of cruising I quickly realized that wasn’t enough. So I hastily bought 30’ of 1/4 HT & 250’ of 1/2” 3 strand. After a few more weeks of using this set up I’m still looking to upgrade most likely with an electric windlass. The average depth that I’ve been dropping the hook is 30 - 80’. Since I’m new to this whole anchoring thing I’ve been a little nervous getting to shallow. Generally I’ve been following The Coast pilot and Navionics recommended depths and known locations. There are a few coves on the chart with even deeper anchorages and I’d like to eventually have enough ground tackle to check them out.
It sounds like all chain is pretty popular with world cruisers. Definitely don’t plan on cruising outside of SE Alaska or getting too far from land in our Cal 29. It sounds like one major advantage is chafe protection against corral. Don’t think we much of that going on up here, but potentially sharp rocky bottoms?
This is what I’m considering, what do you guys think? Should I go bigger on any of the aspects? Obviously as I price out components for a bigger setup it starts getting pretty spendy
( Welcome to Boat ownership I guess!)
1. Electric windlass- Anchorlift Barracuda 900 or Maxwell RC6, or other similar entry level windlass
2.Chain 100 ft of 1/4” HT
3. Rope 600ft of 1/2” 8 plait
4. Rope chain spliced together with a 5/16 shackle at the anchor end
Should I consider a swivel instead of Shackle? Should I look into an oversized welded link on the end to accommodate a larger shackle?
The other choices I’ve contemplated are obviously upsizing all of the above to 5/16” chain and 5/8 rope, and heavier duty windlass.
Also, I’ve thought about a manual windlass for cost and simplicity
Thanks in advance!
Thanks in advance!
