G
Greg aboard 'BlueBerry'
On my '88 L-37, the p.o. had installed an electric windlass (thank you very much!). As I am still "sorting out" this new to me boat, I keep coming across things that i could use some sage advice on. To wit, it seems that the p.o. had relied on the windlass and chain rode to keep the anchor, when not in use, snug up against the roller. Although that may be ok, i would prefer to have a backup of some sort. My dilemna is that I am not sure how to do that. I believe the anchor roller is stock, and i am carrying a bruce anchor on it. There is a set of holes in the "channel" of the roller assembly, which conceivably one could put some sort of pin through, but then I would have to drill through the anchor, since there is not a hole it lines up with. There is a hole on top of the anchor (for retrieval or trip line) but that is too high off of the roller assembly to connect to anything. I don't think I can go with an in-line chain tensioner, since the chain is raised above the deck, in order to feed the windlass. So, who has good ideas to offer up!
