Today while cleaning out and organizing my anchor locker, I noticed a significant crack in the bottom of liner. Water has to be getting in there. Water can easily enter thru the hole in the cover and non-watertight cover edges. I checked inside the bow of the boat and didn't see any obvious signs of leakage, which I find hard to believe. I do find some water in the bilge after a heavy rain. Could the water make it way to the bottom of the boat from the locker? The drain in the locker was not clogged. What is the best way to fix the crack? sealant, resin, fiberglass, or some sort of rubber or vinyl liner that I could cement to the locker bottom and sides? ThanksJim
