I have the same model and year and had the same problem. I started on the project because the boat smelled of mold after it was in storage. I solved the problem a few years ago by fiberglassing over the joint between the deck and the anchor locker. Since joint is covered by the anchor locker lid, it doesn't have to look the greatest. I think the problem is worse in storage because it is blocked with the bow up higher then when it is in the water. I used resin and fiberglass matting (not just body filler) and tried to make a pretty secure joint.
When I did this I also removed all the foam and vinyl wall coverings. Water was coming in the anchor locker/deck joint and running down behind the vinyl wall covering in the V-berth. When I removed the vinyl covering, the foam backing was soaked with water. Replace the vinyl covering (which couldn't breath) with the cheapest, thinest nylon carpet I could find (Walmart) so any water or condensation could dry out. Most of the edges push in behind the existing trim, etc., plus a few dots of silican caulk to hold in place. I started in the v-berth, but ended up doing the entire boat. Not as much work as I expected, and very happy with the results. The changes really changed the way the boat smells.
While I was doing fiberglassing, I also took care of the standing water in the bottom of the chain locker. On our boat the drain hole was about 1/4" to 1/2" above the bottom of the locker. I took the left over fiberglass and poured in the bottom of the chain locker to built it up higher than the drain. You have to stand on your head and hold your breath, but you can smooth out the fiberglass and make a drain channel for the water.
