anchor locker drain
20
Oday 23 Ranier, MN
I recently discovered a new leak in the bow of my Oday 23. It looks like it might be coming from the anchor locker drain, or it could be the u-bolt just below it. I plan to rebed those fittings this winter. The thru-hull fitting is metal and looks like 1/2 dia. I'd like to replace it with a mushroom head, but am afraid the diameter would be too large for the stem. Any suggestions?:confused:
992
Oday 25 Gibraltar
For the anchor locker drain I used 1/2" copper pipe. Flared the outer end just a bit and it fit right in.
Rich
Jan 22, 2007
268
Oday 23 Cedar Creek Marina Bayville NJ
I found the wood behind the u-bolt was rotten so I replaced that and reenforced it with some resin and glass matt. You will most likely need to do the same.
As far as the drain goes I found a barbed fitting at one of the box stores that fit the hose and JP-Welded it in place. Has not leaked for seven years.
