Anchor lines and chain
Jay Kent
I have read lots of articles and materials on the proper size of line and chain to use for anchors. However, I would like to present this to the forum for input, as I am getting "mixed reviews" about formulas, etc. Here is the boat that I want to "re-equip" before Spring put-in: LOA 27; width of 8 feet; weight, approx. 7300lbs. Anyone care to offer their "2 cents" about size, length, etc.? I am still open to listen before my purchase of materials. Thanks to all.
Dec 2, 1999
15,184
West Marine Catalog
Jay: W/M and several other catalogs have guidelines on ground tackle sizing. Whenever you are in doubt just move up to the next size vessel and you will be more than safe. There are also some anchor tests in practical sailor about anchors, you may take a look at those too. Be sure to get an anchor that works well in conditions in your sailing area. Some anchors such as the danforth and Fortress work very well in sand and mud but are almost worthless in grass and weeds. I think that the getting too big of an anchor and tackle is just as bad as too small. When you are trying to retrieve these without the proper equipment (windlass) you can hurt yourself. You also must consider storage. Will the equipment fit in your lazarette or anchor locker.
Jim Ewing
Ditto on Steve's response
West's chart is pretty good. I think Practical Sailor also did some anchoring articles in the last few years too. I think in general manufacturers recommendations are two small, go one size up. I have a 37.5 which displaces about 18K#. I carry three anchors all of different types. For general purpose look at a CQR or Delta. I use a 44# Delta and it has always (except when I first got the boat and was learning) set the first time and stayed set. My second anchor is a normally sized (33#) Bruce. The delta works so well I almost never use it other than to practice setting it. My third is a big Danforth. It's there if I ever need a kedge. I carry 50' of chain and 150' of nylon on the delta, 35' of chain and 150' of nylon on the bruce, and short (10') of chain and 100' of nylon on the danforth. I usually anchor in 10' or less of water. I think the recommendation is for at least a boat lenth of chain and as much nylon as you need for proper scope. If I were to change anything it would be to put 100' of chain on my primary but so far I haven't had the need. Jim "Prospect"
A
Andy Howard
over size and quality
If you like to anchor out, you'll eventually wake up one night at 2a.m. with the wind howling and the waves rolling. That's when you'll appreciate the 5/8" line from New England or Sampson, a little chafe gear, and that extra foot or two of chain down there. And if you decide to go with a danforth style buy the best you can afford. I've got a bargin knock off with the stock bent at a 90 degree angle.
