Went for a sail w/ the admiral and our 2 little deck hands. Dropped anchor to get in some swim time. After a short while of swinging on the anchor, I went forward to make sure all was well and noticed the anchor line rubbing on the roller furling bracket. I thought about releasing the anchor and running it arould the front rail support, but decided that would best be done when not hanging on the anchor. Will it cause any problems if I do that, or am I doing something wrong to begin with? There's just a little bit of fuzz on the line from rubbing, so the line should be fine. But if I continue as is, it will make short work of the line and I'll be replacing it. What have you folks done?
