Anchor light
716
Oday 30 Anchor Yacht Club, Bristol PA
I've a friend that's going up! What bulb would Oday have used up there originally? I picked up a LED but it would be nice to know before hand and save a trip up the mast for my friend.
thanks all!
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
I replaced mine (Aqua Signal series 34 I beleive) with the Dr. LED festoon star white led replacement bulb this spring. It was a simple bulb change, just make sure it isn't wired backwards as mine was, the LEDs are polarity specific.
Before anyone says anything about uscg certs, the led is twice as bright as the incandescent bulb it replaced (as measured by my eyeball, at night), probably a result of some voltage drop going up the mast dimming the old bulb, but not the LED, but whatever the reason it is visible for MUCH farther than before, so I dont care if it has a stamp of approval or not because it works better than the bulbs that do.
Apr 8, 2010
1,606
Correct, but there are at least 3 different types/sizes that i know of though, and all use the generic name festoon. Conveniently the LED bulb included adapters to fit all 3. I dont know what anchor light you have on your oday, but my Hunter uses a complete matching set of nav lights, so my bow lights, stern light, and anchor lights are all aqua signal series 34 (I think, cant check at the moment, on my phone...)
Chances are good that your oday is the same, so whatever bow lights and stern light you have, they probably match the anchor light.
Feb 26, 2009
716
Well I guess I'll have to have both on hand when he goes up the mast.. thanks!
Jun 11, 2004
1,828
Oday 31 Redondo Beach
I'm pretty sure the anchor light on my 1985 O'Day 31 is a Lucas brand and takes the regular bayonet type bulb. I assume it is the original. I'll check it out tonight if you want
Jun 11, 2004
1,828
Welll it's not a Lucas. It is a Hella 2492 and takes a single contact bayonett type bulb, BA15s.
Bulb
12V / 10W BA15s included
Not sure if it's the same as yours but I hope that helps.
Feb 26, 2009
716
Sigh... I have the dual contact type.. another trip to waste marine today!
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I'd bet money that its a bayonet type bulb and not a festoon cause they could slip out of the socket if banged around and having it 50 something feet in the air would be a disaster......buy a bunch of different bulbs from West Marine and bring back what you don't use
