anchor for a 9.2a
73
S2 9.2A Battleship Cove
My 9.2A came with 2 anchors, both Danforth style, one is a Fortress, the other a common galvanized steel version. Although it's nice to have 2 anchors, I think if I'm going to carry 2, they should be different styles.
So I'm thinking of either a plow or claw style. Does anyone use either of these and if so, what size is best for the 30' S2?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i have a 22 lb bruce and a danforth on my boat but where you are may dictate what you need ....
regards
woody
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
The Danforth is common in our waters. I have been thinking about a second and would probably buy a 25lb Manson Supreme off ebay, as the price is the best I saw when I last researched it. There is a nice treatise about anchors and a ton of discussions.
http://forums.sbo.sailboatowners.com/showthread.php?p=663739&highlight=rocna manson anchor
My reasoning is to add a plow type anchor, which would be quite different in setting characteristic than the Danforth. The Rocna would be my first choice, but I just can't justify the cost vs. the Manson. The roll bar seems a valuable addition. The biggest downsides to the Manson, from what I have seen, is the shank design makes it tough to fit onto a bow roller. It is also not as pretty as a Rocna.
The CQR is a very popular storm anchor in New England, but it is interesting to see the youtube video by Mainesail. CQR's are also pretty expensive.
Hejira
May 18, 2010
15
S2 9.2A Woods Hole, MA
I have 2 anchors onboard. Both are the maximum size possible to fit in the locker. I use the plow 95% of the time on this trip to the Carribean. The danforth is handy around Cape Cod. The plow is about 35# and the Danforth is a light duty, but a very large size. Go big. Totally worth it. I have 16' of 3.8" chain on both, with half inch nylon for the remainder. Sometimes I have had to anchor in 30' of water, so you need about 200' of total rode. This is a cheap and easy setup that has worked perfectly for 6 months. I keep 100' of 3/8" chain in the locker for emergencies, although I have never used it. Extra mooring penants, rode floats, a couple shackles, and a trip line are also in the locker along with a heavy set of commercial fishing gloves in orange.
http://www.travelpod.com/members/hejira blog:
Jul 22, 2006
73
Thanx. And the work gloves in the anchor locker are a great idea! I don't know how many times I've pulled up a mooring line - especially a guest mooring - only to find that its encrusted with barnacles and slime.
