The chain hook is never much below the surface. If (when) it occasionally falls off I can see usually see from the bow. There is also some twist of the snubber line around the chain when "slack", which helps to keep the hook on. I actually have a second one made up that can back-stop the first one although it's not usually on in "normal" conditions. In any event, shock-absorbing is but one function of a chain snubber or any snubber; the other is to spare the load on the windlass from most strain, most of the time. I rarely experience shock-loading at anchor b/c I don't anchor in places where the boat pitches much, or is otherwise facing conditions causing shock-loading. If I needed or wanted to anchor along an exposed coast facing seas, then the shock-absorbing qualities would be very important.With a nylon rode, the only purpose would be as bridle, to reduce sailing at anchor. Multihulls do this.
The problem with a chain hook and a long snubber is that it will come off if it lies on the bottom. I've had this happen a few times (a very high percentage of the time it laid on the bottom). The solutions are:
For the OP, I suggest the camel hitch with a dock line is probably the simplest answer. Not perfect, but darn good and simple.
- Shorten up in light winds (but they could change).
- Use a locking hook.
- Use a prusik hitch, double rolling hitch, camel hitch, or soft shackle.
Part of the risk of chain impact is damage to the boat or ground tackle, but far more likely is dragging anchor.
http://www.csjohnson.com/marinecatalog/s00056.htmWas reading your post and wondering where to purchase a Captain Johnson hook?
Thanks
I think I bought it at WM when I took delivery of my boat and realized there was no snubber onboard. I like the over-the-link cradle-style chain hooks.Was reading your post and wondering where to purchase a Captain Johnson hook?
Thanks
Dragging is the big problem. A long snubber can reduce the loads by 1/2 or more. The loads, obviously, come from wind and waves.What shock loads are you dealing with?
Thank you.15 feet of snubber would be on the bottom in most Chesapeake Bay anchorages. For me, 8 feet might be (I only draw 3.25 feet--if you are always in deep water, the issues are different).
