Your anchors are on the heavy side....
for your size boat, but that just gives you a better safety margin, so no need or use to replace them. Even if you did, you'd only save perhaps 5 or 8 pounds, for the cost of a lot of boat bucks.Your 90 feet of chain, however, probably isn't doing you much good. Chain has 2 characteristics which make it important for anchoring: chafe resistance and catenary. Chafe resistance is a concern mostly around coral or very rocky anchorages. If this is a serious concern for you, then you should get more chain so you can have an all-chain rode.Catenary simply means that the weight of the chain forms a curve under most conditions that causes the pull on the embedded anchor to be closer to horizontal, which is ideal. The two conditions where catenary is NOT a consideration are:1. There isn't enough force on the boat to make it lift all the chain off the bottom, so it 'rests on the chain'. This is characteristic of extremely peaceful anchorages, so your long chain isn't doing you any good.2. The force on the boat is high enough to lift the chain off the bottom, making the anchor rode essentially straight from the anchor to the boat. Once this condition is achieved, you're better off with all-nylon, due to its elasticisity (sp).For your 90' of chain, assuming you are anchored in 12' (plus 3' to deck level), the force necessary to lift all your chain off the bottom is 377 pounds.If you decrease your chain to 30', the force necessary decreases to 41 pounds.(for those who want to do the math, see the link below) - (in general, the 'anchor catenary factor' increases by the square of the length of the chain)That probably looks like a significant difference, but is it really? I don't think so, and here's why:Once the rode is taut, you have to deal with angulation, which is the angle between the bottom and the rode. Any angle greater than zero (horizontal) decreases the anchor's holding power, which is why SCOPE is so important, because it decreases angulation. Once the rode is taut, the chain ceaces to provide any advantageA 35# CQR (or a 33# Bruce), properly set, has a holding strength of several thousand pounds - this is a very subjective number, but let's say it is 1,000#. So here's my point:While 90' of chain won't go taut until 377 pounds of force are applied, that is still WAY short of the holding power of the anchor.......and once the rode is taut, the extra chain is actually a detriment rather than an advantage, because the elasticity of nylon helps absorb high shock loads. And since your anchor will hold just fine when the force is between 41# (with 30' of chain) and 377# (with 90'), those extra 60' of chain aren't really anything but more weight in the bow, and more strain on your back.So to answer your question #2, Paul, by the time you're sitting out a hurricane, your chain isn't going to do you any good - in fact, as a guess, 30 knots of wind will draw your rode tight even with 90' of chain.My 2c: use the CQR with the 25' of chain, but a longer nylon rode. When it's blowin' like stink, SCOPE is the critical factor, because it decreases angulation and, as we've seen, it's ALL about the angulation.
Cheers,Bobs/v X SAIL R 8
