Please help me avoid an extra trip up the mast ! Does anyone happen to know what bulb or even what brand O'Day used on the 34 for the anchor light or the steaming light ? Thanx in advance ! Cap'n Ron,Miami
Cap'n Ron, Even if you knew the correct bulb to use, given the age of your boat the sockets may be corroded to the point they are no good. You may want to consider new fixtures. They aren't expensive and are universal and easy to mount. The new ones Ive seen are better sealed than the older ones. Good luck Ray T
The guy I work with calls that mileage...
two trips, take a camera and tools, that way it won't be three trips.
Include in your tools a tester to check to make sure that the socket is getting power.
r.w.landau
