An idea for Cabin Lights...
I was at a trailer supply shop Saturday and saw these... They are fully enclosed backup (White) LEDs. They retail at $22. Can anyone think of a reason these would not make excellent cabin lights?
I'm thinking low draw, durable, bright and cheap (compared to anything with Marie on it).
Anything I'm missing?
r
6,243
S2 9.2a Fairhope Al
r
i dont see why they wouldnt work ....people burn oil lamps on board .....
regards
woody
regards
woody
:D Yeah... I got one of those... just figure there must be a reason you don't see them. Like maybe they attract bugs more than other lights or something strange. :confused:
Sep 5, 2007
689
MacGregor 26X Rochester
I'm guessing too bright, and too direct. But I don't see any other reason.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
During my recycling project I've more than once shopped the RV suppliers. Low and behold I found the exact faucets and dome lights that were original equipment on my 76 Oday 27. And the price was probably less now than when it was built.
Aug 2, 2005
374
pearson ariel grand rapids
Only issue I could see is that they are designed more as 'beams' than as an all arounder.
Mounting them under a frosted lens would possibly diffuse the light more and make them better for cabin illumination.
I have a couple spot style lamps, and while they're great for lighting up a spot (of course!), they're useless as area lights/general illumination. You always have a bright spot surrounded by a dim area, made to look even dimmer because of the bright spot.
Best way I've found to use them as general purpose lighting is to aim them at a white surface and let the light bounce. They work great for room lighting that way, bright enough to read by nearly anywhere in the cabin.
Aug 20, 2011
75
Macgregor 25 Sacramento, CA
With an led bulb if the lights too direct some folk sand/scuff the tip to diffuse the light. Or if you install in a fitting with a frosted lens that may do the trick. I found some nice fittings at our local reuse store and my plan was to wire up with leds cause there such low draw, now as I'm thinking about may put in a mult-position switch to get different light levels while I'm at it.
caguy
Sep 22, 2006
4,004
My old Macgregor was outfitted with 2 light fixtures, the were made with two 12" flour scent tubes. They did not appear to draw much but put out a lot of light. I'm not sure of the specs I suspect 15 watts. I liked the color and tone of the lights, they were not harsh. I don't know if they were standard issue or a mod by the PO.
2,117
For about the same price, you can buy marine grade interior LED lights ... like on a couple of pages on this forum's sponsor site for example:
http://shop.sailboatowners.com/prod.php?5207
http://shop.sailboatowners.com/prod.php?6240)
One thing to consider is the color of the "white" LED's. The color of many white LED's is a cold looking blueish. (I suspect the one you are looking at probably is a blue hue LED fixture). Other white LED's are described as "warm" which is closer to the yellowish standard incandescent bulbs we all grew up with ... and also that the current crop of screw-in florescent bulbs emulate. The warm color is desirable if you want a more cozy feeling in your cabin -- rather than lighting for a jewelery store display.
Since these are cabin lights, top-of-the-line voltage/current regulation probably isn't critical but still some degree of of regulation is still desirable.
Or check out eBay. Yeah, a lot of the offerings will be shipped from Hong Kong. But you will find a huge assortment of color, fitting type and lumens for 12v applications.
The price of LED lighting -- with much better lumens than before -- has dropped a lot over the last several years.
Anyway, you might want to look around more before getting the LED back-up lights.
Oct 14, 2005
2,191
Hey R...
on my last boat I used some red marker lamps and trailer brake lights for night vision lighting in the cabin. With the new LED lighting units you'll save a lot of battery and provide lots of light. Look for a couple of red ones if you sail at night.
Go for it!
Go for it!
Thanks Dan: You actually hit on something that has been creeping in the back of my mind. I've been thinking about the yellow/orange lights you see as running lights on the sides of trailers.... They are the same color as the porch lights (bug lights) people use on their front stoop... and they are sort of in between a white light and a night vision light.... A compromise to be sure but maybe one I can live with...But once again I figured that if it was a good idea, someone else would be doing it already... but they are not expensive so i just might try one and see if I like it or not.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I've just ordered a strip of waterproof led lights from ebay for my mac 26D. I went with the strip because it is low profile with a sticky backing and can be cut into 3 led pieces.
http://www.ebay.com/itm/Waterproof-...047?pt=LH_DefaultDomain_0&hash=item2a1727e18f
I think this will be the best type of light in our tight quarters. It will allow for lights to be placed in spots not usually accessible for conventional lighting. Like that spot at the foot of the aft berth.
BillyK
Jan 24, 2010
502
Catalina 310 Ocean City, NJ
I'm curious how these will work out for you... i wonder if the sticky backing will hold when the cabin hits over a 100 during the summer..
Nov 8, 2010
11,386
Make SURE that have on-board voltage regulation. LEDs get very hot (and bright) when fed more than 12v. Having non-regulated LEDs on when charging your batteries can make them hot enough to melt solder.
Jun 6, 2006
6,990
If they work on a car/truck electrical system then they should work on a boat with 12 volt system. Just don't turn them on when equalizing the batts.
Jun 9, 2008
1,801
- -- -Bayfield
The issues I would be aware of (and many are touched on in this thread) are: Too bright or too concentrated for a cabin light (some people like a more soft illumination in the cabin); voltage drain too high in comparison to cabin lights; the materials are not corrosion free (most trailer lights are made of steel and will rust while cabin lights are made of materials that will hold up to a marine environment).
Frank, those are fixtures that were used on many boats, we have one in the galley on our boat.
I buy replacement lamps at ACE Hardware, my favorite boating store. The lamps come in both cool white and warm white. The original lamp was a cool white. It was horrible. The warm white made all the difference.
Just like LEDs.
r
Why not ask to have them light one off for you, so you can see the brightness and color rendering?
Nov 8, 2010
11,386
yea maybe... but why not just buy marine hardware? It costs more, but there's a reason.... SUVs don't sink. Boats do. I get the willies when ever I see someone walk onto their boat with a PEP Boys bag.
Thanks all for your input. At the moment I have LED accent lights in my cabin... and they are flaky. I'm always running down a short. So I've been thinking about the best way to change things... and since posting this thread a month ago, I've decided to go in a different direction...
http://www.amazon.com/Dorcy-41-1092...W2/ref=sr_1_14?ie=UTF8&qid=1324316150&sr=8-14
These are mini-LED camping lanterns. A set of batteries will easily last a season so I'm going with the "keep it simple stupid" approach. And this will open up a switch on my panel for something else.
