An Easy way to Varnish Teak Handholds
Tim Dranttel
I feel like a bum for trying to find an easier way to complete a task so I can spend more time at the helm... but here goes. Does anyone have an easy way to mask the cabin top hand holds in preparation for varnishing. I started to just use the "blue" masking tape but this is incredibly tedious as the tape does not conform to the contours easily and takes about 6 pieces of tape for each handhold-to-deck mating. As I have 22 of these junctions to mask I got to thinking that "there has got to be a better way!" Thanks for any suggestions! Tim
Trevor
Nelson and Niemen Manufacturing
... I found an outfit that saw a need in the market for this universal problem and came up with a potential solution: pre-cut handrail masking tape. I haven't used this stuff so can't comment on whether it's worth it, but check it out. Click link below to go to their web site. Trevor
L
LaDonna Bubak - CatalinaOwners
You beat me to it, Trevor!
I've seen this product and have thought aobut using it but it's so darn expensive! I guess I'm a true sailor cuz I'm so cheap!! Anyway, I think it's made of the 3m blue tape so it should work pretty well. And good for you for varnishing!!! :) LaDonna
Brian Ranniger
Take 'em off
I took them off first so I could strip them with Citri-strip. Much easier than sanding varnish. Only problem is...holes for water to leak in (dab of silicone fixes) and they are a royal pain to put back on singlehanded. Get help and it's very easy.
Thos. Kober
Unfortunatly there is no easy way to do it ..
I just did it and yes it takes time but in the end it is worth it to do it right. I used the blue 3m tape - (Excellent!) rolled out one long strip on the outside and one long strip on the inside, then I used two to four small pieces around each corners and curves. In the end the time you spend putting it down will be a lot less than the time you will spend cleaning up drops ..
Rob Rich
I'm with Brian...
I just take 'em off. Use a cordless drill/driver, you'll have 'em off in no time. Allows you to really get at them and put on a bunch of coats. I gave mine 8 coats. They have been on about 9 months and there is no deterioration whatsoever. Rob
