I see
If you look closely, they have the bags tied to lines and tensioned slightly (they arent hanging straight down). My guess is that the bags are heavy enough without beign restained, any heel maks them fall "downhill" and causes the boat to heel over until they lay in the water and then tighten them up, or perhaps only until they reach the extent of the lines. To stand back up, you just reel them in! It's in in weither or not the bags have enough weight to overpower the heel even at a small angle of heel (the systme is stable - the bags have more heeling moment than the boat at any angle of hel. If they were only stable when far out, it would be a pretty dangerous rig and I dont think you could keep it there with line - you'd need a whisker pole or something.
