Hi Joe, one 30 amp dock service should be fine...
Our boat is equipped with two 30 amp service cords and sockets, too. In the five years we've owned the boat I have never connected both cords. One 30 amp has always been enough, marginal sometimes, especially coming into a marina after being on the hook for a few days. The charger wants to take almost the entire service to bulk charge the battery bank. After an hour of bulk charging it steps down to where the 30 amp is plenty.Now, if we were in a hot climate and needed to run both heat pumps then both 30 amp services would be needed. Each draws about 12 amps when running. You may find that 30 amp is just fine. It depends on your power requirements. Hot water tank takes 10 amps until the water is hot.Terry
