Is there anyone out there using the Ample Power Monitor Ii? I'm am curious as to what parameters you have programmed into it. I also have installed the Ample Power SAR regulators
I would like to know if it goes from absorption mode to float on a timer or when the batteries, 675ah gel in my case, are nearly fully charged
. On my boat I have three onboard charging sources, the main motor, a aux diesel 12volt 130amp and a freedom 3000. Solar panels are also fitted (260 watts).
I have not checked the charge efficiently of the Peurkets exponent since I am not sure how I do that easily onboard!
Bazzer
Bazzer
