Ammeter replacement questions
Jun 2, 2014
602
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
Thanks for all the advice everyone. I really appreciate it. I like getting all the advice here because even though I think I know what I want to do, it helps to hear what else I should worry about or why to do it a different way than I thought.
For example, while you guys were replying on this yesterday, I already installed the new digital meter. I calibrated it first before I installed it. I know the voltage is super accurate, and I tried to get the current as close as I could to my BK meter using various devices, small 12v heaters, fans, etc. I didn't have anything really good that has a large static load to measure before installing it. It seems close enough.
But, I DID install it on the NEGATIVE side. I have a single 12 gauge negative wire coming from the batteries going straight to the negative buss on the breaker panel. It SHOULD capture everything on that panel, so I'm not sure I need to move it to the positive side now.
But it did also make me wonder how my windless gets it's negative connection. It clearly has a 4ga positive wire on it's own 90A breaker. I don't think the 12ga negative wire is feeding that. But it would be good to know.
Also, I'm not an electronic newb, I know basic electronics, enough to be dangerous. Here's how I always tried to describe Voltage/Current/Resistance, funny it's also water-related!
Jun 2, 2014
602
1/0 is a great way to upgrade your boat. Might I suggest MRBF fuses at the battery also. A 200A fuse can still start your boat and still prevent that wire from turning into an arc welder burning a hole in the boat.
I meant to install one of those and kind of forgot about it then I couldn't remember what they were called. Thanks for reminding me, I just ordered one for the connection to Batt#1 Positive.
Feb 18, 2022
440
Catalina 36 Port Orchard
The purpose of the colors is to prevent confusion. Red = DC Positive. Black = AC Neutral or DC ground. Yellow= DC ground , white = AC hot, Green = AC ground. yellow is preferred for DC ground over black to avoid confusion between AC & DC.
Les
One minor correction here:
Black = AC Hot
White. = AC Neutral.
This is why Yellow and not black is recommended for DC Negative to prevent confusion.
Jun 2, 2014
602
Okay I replaced the 12ga negative that went from the battery to breaker panel with 8ga, rewired some of the positive terminal blocks to not be all stacked up, installed a 200A MRB fuse on the battery1 and installed the new ammeter in the wooden panel below the breaker panel. And I replaced one of the On/Off Carling switches that was intermittent I haven’t removed the old ammeter yet but it’s out of the circuit now
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Talk about preventing confusion! How about just now sowing confusion? (What's wrong with the above quote?)
Likes: mikeracca
