have you considered a guage such as a Xantrex XBM, currently a Linklite,
Yes, but maybe not this year. We'll see after all the other bills come in. I can buy the ammeter and shunt for under 15 bucks if I don't want the packaging I throw away to say "Blue Sea" on it.  At this point, I primarily want to run 20 hour tests on my batteries and start getting a handle on what my actual electrical usage is.
BTW, the ammeter was an important instrument when I was flying even though it was a tiny toy without even any numbers.  As ammeters go, it was the equivalent of those little compasses they give away in Cracker Jack boxes.  The master switch on most airplanes st a double switch.  One side turns everything in the airplane on and off similar to a boat's battery switch.  The other side turns the field to the alternator on and off and I'm thinking such a switch would be a good addition to a boat.
High compression aircraft engines really suck the amps starting up and the batteries are small. Having the alternator out of the circuit frees up a several amps for starting.  This could help if you were trying to get a boat engine going on the last dregs of a battery.
After starting the aircraft, we would note the ammeter needle position, turn on the alternator, and then watch the needle move back to its normal position over about half a minute.  This confirmed that the charging system was operating normally and the starter wasn't stuck engaged and turned into a generator that would fry tens of thousands of dollars of avionics.  Even without numbers, we got used to the exact behavior of the needle and could spot any change in the way the charging system was behaving.
A field switch on a boat would also be a good thing to have if you found yourself in an overcharging situation due to regulator failure and couldn't safely stop the engines.
The regulators we had in the plane were the old "doorbell buzzer" type until just before I stopped flying because the FAA makes it incredibly difficult to bring in new and improved technology.  Small aircraft lag about 30 years.  It's amazing they even permit GPS.
