If any of you follow this site you'll know I posted last fall About whitish smoke and a loss of power from my 1983 Yanmar 2gm in my hunter. Well this winter I stripped down the top end expecting to do a valve job. When I got the top end apart the head and cylinders looked GREAT. I did clean out the exhaust manifold , reamed the cooling passages with a wire rod in both the block and head and cleaned out the temperature manifold. After all this I noted that the thermostat appeared to be stuck closed. (It would not open in a pot of boiling water. ). I replaced the thermostat and all the various gaskets and bushings. Polished the cylinders of a very small amount of carbon. The valves looked so clean I didn't even bother checking the specks. I put it all back together with no extra parts. Other than a small problem with the water pump! I replaced the impeller and I think I had the impeller vanes flipped backwards, which I fixed by opening it up and making sure the we're flipped correctly , and the standard bleeding for air. She started right up and purrs like a kitten.
I also replaced the alternator because I broke off one of the electrical studs while removing it.
So the problem might have been a minor overheating issue causing steam. (. I backed off on the rpms as soon as I saw smoke last year.)
I am very impressed with the engineering of this motor. If after almost 30 years of hard use she seem to have very little wear! Wish I were the same.....
I think I may descale the old girl next season but it doesn't seem to be necessary.
Anyway, we splash on Monday and I'm looking forward to a good sailing season.
Thanks to all you out there for your advice last fall.
