I've done this
I installed an Icom 706 on my C-30. I used an HF whip; it’s a Shakespeare, West Marine P/N 47994, transom mounted . It is large; you may not want to do it this on your 25. But hey, it works well. The antenna is connected to an SCG 230 antenna tuner, then the 706. 6/2/70cm is handled with a mast-mounted whip. I’ve had good DX performance with it.Your biggest challenge will be a good counterpoise. It took several tries to get mine right. I wound up with several 4” wide copper straps bonded to the inside of the hull below the quarter birth and inside the laserette. Once all tied together I got a good match on 10, 12, 15, 17, 20, 80 and 160 meters, but the 40 Meter band still eludes me, the tuner won’t match it. Insulated backstay antennas seem to work fairly well, but the insulators are costly to purchase and on your 25’ I wonder if the backstay would be long enough, although I know a Flicka (20’) owner that has his rigged this way and gets good results with the Icom antenna tuner.John – KE6PID
