I'm wondering if this is normal or not. I've written everything I can think of to describe the situation:
I've had my H23.5 for 14 years now. I only tuned the mast once, maybe 10 years ago. At the time I set the mast rake by hanging a wrench from the main halyard and measuring at the goose neck. I have a Loos gauge for the shrouds. After setting with the gauge, I then understood what the Hunter factory guy told me about the shroud tension being "guitar-string tight". Well, I play guitar and wasn't sure what he meant. What I noticed was that as you increase the tension, "plucking" the shrouds changes from a sloppy "thwack" or "thup" or "blap" that stops immediately to a very low tone/vibration that carries on for a couple of seconds or so. (Dave - I'd be interested in you opinion of this since you do it by feel!)
The turnbuckles on the forestay are completely wound closed - no more threads left. Every time I lower and raise the mast (not very often), I have to remove the cotter pins and completely loosen the turnbuckles to nearly the last threads in order to get the pin out.
About 6 years ago I moved the forestay pin to the forward hole in the plate. I'm not sure why now, although probably because the forstay seemed loose (saggy). I don't know why I didn't tighten the shrouds instead.
I have Schaefer Snapfurl which covers the turnbuckle, so all-in-all it's quite an ordeal to lower the mast.
So, does this sound normal? It seems to me that backing off the forestay turnbuckles to the center and tightening the shrouds would not change the situation, it would only increase the mast rake. Should I just be more aggressive with the mainsheet/gin pole? When I have the maximum tension on the mainsheet when the mast is up, the gin pole is horizontal and the mainsheet blocks are nearly touching (no more room to tighten). I would need to set the gin pole angle greater to be able to harden the mainsheet more. I've been afraid to use this much force.
