Good points
Before I put the new packing in last weekend I was quite concerned with having a problem. I recall reading a number of discussions here and on other forums about doing that and had gotten the impression that it was quite tricky, things could go wrong, and you were in danger of sinking before getting it back together. As a result, I'd put it off much too long.I was quite surprised to find it wasn't a big deal! I figured I'd try to stimulate a bit of discussion on doing things without hauling, which, except for actual underwater glass work or bottom painting, can almost all be done in the water. That's not to say it's always the best or most efficient way, but in a pinch, I think it can be done. And I didn't take Steven's comment to be a negative comment at all- just another view, which is good here.I did get an out of the water survey when I bought Rainbow Chaser - heck, I'd never been on a sailboat before, I needed to learn as much as I could.A little story - back before we went cruising I needed to pull the motor out. It was completely rusted, the oil lines need replacing, the engine compartment was a mess. The thing weighed about 800 lbs (3QM30) and I wanted to do it myself. I rigged up a line from the boom to the spreaders to help support the weight, then used the main sheet and some blocks to lift it out and put it in the cockpit. I moved it fore and aft with a boom vang.The people at the marina were shocked. When it came time to put it back, they were trying to put me in touch with a number of people with cherry pickers and other equipment. My comment was, "Were those people going to be around when I broke down in some deserted harbor?" I put it back myself, using only what I had on the boat.A couple years later I lost the transmission in Louisana. I wasn't to worried, though, because I knew I could do the repairs right there with what I had.I'm sure there are more things I could do for myself, and some of you guys can probably teach me. I'm all ears (well, eyes, I suppose)
