Rick9619
Hey gangOn return from the Newport to Ensenada race, we learned a couple of things. We were in the yes you can run the motor at night if you choose. First, fuel burn on a 3GM30F goes up exponentially, from our normal cruise of 22-2600, if you are leaning on the throttle like Quint trying to get a big shark to the taxidermy man! Secondly, if you didnt do the math and elected to not get gas in Ensenada for the return trip, you can actually flame out the little iron aux! Bummer. That being said, we called VA to get some fuel headed our way, and meantime, I changed out both 10 microns, with two new ones. We put five gallons in and something wasnt right. I couldnt get a good flow of fuel past the filters to the mechanical pump. I used the oil boy and it was building up lots of suction. I did the research here and it does seem my pick up screen is clogged. HAS anyone just taken that out? I run a duel 10 micron racor setup with a two micron at the motor. If this isnt a good idea, can you blow air back thru to unclog it or do you need to take it out? Can you get the crud out of the tank by using oil boy through return line? Thanks again.
