Ok, I've been reading around on here, read (not necessarily understood) Mr. MainSail's musings (wow... lotsa good info!) and article's like "Battery Voltage vs State of Charge"....and I'm pretty confused. But here's my situation:
Weekend sailor. only once in a grand while doing any overnight cruising at this point in our lives. We usually sail about 4 hours almost every week. Catalina 309. One 4D and one group 27 flooded batts. 55AMP alternator. Usually start and run on 4D batt only, head out about 20 min much of which is at 3k rpms, then sail several hours with vhf, gps, nav instruments (and rarely use autopilot). Then start up and head back in (20 min / approx 3krpm for much of it).
Every 4 to 5 weeks I start on the group 27 battery to see that is is working, when I do, after starting, I switch the batts to both for charging - never starting on both.
The batteries seem to be maintaining using the above procedures.
My question: is that going to harm them? I have a Blue Seas charger (P12 - 25amp), but have rarely used it. Do I need to add a "once a month" full additional charge cycle all the way to float on the Blue Seas to keep the batts healthy?
Thanks for any insight - David - Tampa, FL
