My O'day 35 has molded in toerails that are capped with a beautiful teak accent. That beautiful teak accent is no longer beautiful and must be sanded and revarnished. I have no problem doing the work and have done it before on other boats by completely removing the wood and refinishing it and properly bedding it back in place. However, on the previous boat, the wood was the entire toerail so it needed to be there. The current boat as I said, has the molded toerail so the cap doesn't really need to be there. My question is this, anyone see a problem pulling the teak off and using it as a pattern for an 1/8" x 3/4" aluminum bar to cap the toerail? It would bed like the teak and be much more durable and no maintenance other than re-bedding occasionally. I even thought I could have them anodized. The other option would be to remove the teak and fill the holes, gelcoat and be done. Third option, redo the teak. Any opinions?Ignore me stumbling out of the boat an look down in the lower left corner of the photo to see the toerail.
