Aluminum or stainless, and type, on mast support pole, Hunter 23.5?
Dec 26, 2021
47
Hunter 19-2 Seattle
I need to extend my mast support pole on my Hunter 23.5.
This is made from either stainless or aluminum. I can’t tell which. It is the factory-supplied mast support pole at the stern of the boat. Brushed finish.
And. Extra credit if anyone knows the exact alloy. I may take it to a welder and would like to be able to describe the metal when asked.
Thanks!
Jun 2, 2004
3,670
My mast support pole is some sort of aluminum alloy
I would not weld an extension to the support pole to make it longer.
I have however been planning on adding a removeable extension to the current pole to make it taller and to make it possible to raise the starting position of the mast when raising it. Adding three or four feet to the pole would make raising the mast way easier for a single person to do.
I've not quite worked out the mechanics of a single person lifting the current pole and adding an extension to the bottom. With two people it would be simple but with two people you just have one push the mast up while the other pulls up the line on the "main sheet" to raise the mast. A more feasible plan seems to be adding an extension to the top that includes a yoke similar to what is presently there. To raise the starting point, you would attach the extension lift the mast out of the original yoke rest it in the new higher yoke and raise the mast.
Curious as to what your plan is.
341
Hunter 240 Okanagan Lake
I like your thinking. When I’m alone it’s too arduous to get the mast step started. The initial start is the issue. Having the support longer would allow for a much easier single handed start of the lift. If you weld an extension is it still going to be safe for road travel? How long of an extension are you thinking?
Dec 26, 2021
47
Hunter 19-2 Seattle
Why not weld? Much stronger than mechanical….???
And. I am raising my support to clear a new structure. Has nothing to do with raising the mast.
I can (and do) raise the mast solo all the time. Seems easy to me. The gin pole does all the work…I dont think raising the mast support (unless you do like 5’ higher….which will cause other issues) will make much of a difference when raising it. It’s the angle of the line thru the gin pole that really dictates the pulling force needed, and that won’t change much if you raise the mast slightly. Maybe make a longer gin pole if you want easier pulling?
When I raise my mast, I have one hand on the end of the mainsheet line, and the other hand on the line halfway between the two blocks. So I am pulling UP on the very end of the line, and DOWN on the other hand. This opposite motion seems easier. And these is a bit less friction on the line in your second hand, as it has not gone thru the final sheave in the lower block.
341
Well thanks for posting; you kick started my thinking. When I have a second set of hands the only thing I get them to do is lift up the mast then I start pulling.
Cheers
Jun 2, 2004
3,670
Raising the mast support pole will raise the end of the mast while trailering. I'd do some sort of setup where the additional piece is removable. It is also going to be tougher to store on the boat with the additional length.
Jun 2, 2004
3,670
Cheers
If you have a 2 X 6 fender board you can stretch that across the seats for your helper to stand on and it is even easier for the person lifting the mast to help get it started
