Aluminum Holding Tank
Steve B
I was told to write to you about my holding tank. I have a 1991 28 Hunter with an aluminum holding tank. I am going to change it this year. I was told that I can a custom tank made that will fit through the very small lazarette opening over my battery boxes. Can you give me any suggestions of vendors and other equipment that I might need. Thank you very much
P
Peggie Hall/Head Mistress
Get the tank from Ronco Plastics...
they make TOP quality, thick-walled roto-molded tanks, and have more than 400 shapes and sizes--over 100 of which are non-rectangular--to choose from..and for a VERY reasonable price. I'd bet they have one that will fit your space. And you can spec your own fittings sizes and locations, to be installed by them when the tank is made. Their catalog is on their website at: http://www.ronco-plastics.com Before starting this project, read the articles "Installing a Head and Holding Tank, "Replacing Hoses," and "Holding Tank Odor--Odor Out the Vent" in the Head Mistress forum Reference Library (on the right side of the forum homepage).
F
fred miller
Alum. Holding Tank
I would probably replace mine with a plastic one also when the time comes. But frankly, the aluminum tank on my 92' 35.5 seems fine other than being too small. Having more than my fair share of experience with holding tanks over the years, I don't know what all the flap is all about aluminum . .that is assuming you pump it out regularly and periodically through the seanon flush it out with fresh water. Next to glass I think metal is least odor permeable. I can't testify as to the odor integrity of plastic, I just don't know, except I replaced two plastic holding tanks on previous boats because of the odor the tank itself picked up; Maybe it is a reaction with the plastic. The chemical reaction of waste and store bought biodegraders make for a really potent chemical brew. If I could afford a stainless tank maybe that would be the ultimate answer. I stay withn aluminum for now. Let me know if you happen to find a stainless ones. Fred Miller
P
What all fuss about aluminum is about
Although there are rare exceptions (there are rare exceptions to EVERYthing), an aluminum--or any metal--holding tank will typically start to leak at a seam or a fitting within 2-5 years. By the time that happens, the inside of the tank has begun to pit...and once it starts there's no way to stop it...eventually the tank will turn into a collander. The average lifespan is about 10 years, even for 316 stainless...I've seen it happen in less...occasionally seen one go a year or two longer. Although you're right that metal is odor-impermeable (provided there aren't any holes in it), a good quality thick-walled (at least 3/8") plastic tank will last for literally decades without permeating OR corroding. The tank on my own last boat--under the v-berth--was 16 years old when I bought the boat, 21 years old when I sold her, and was in such good shape that it was the only part of the sanitation system I didn't replace. Never a trace of odor...nor will there be in another 10 years. Nor did we ever have a single odor permeation complaint for the entire 15 years we sold tanks. Thin-walled plastic tanks, otoh, may permeate, but few of them last long enough to do it...the average age of the cheapest tanks in the marine catalogs is even shorter than metal because they flex and crack under the weight of the contents. Early plastic tanks were even thinner...after enough bad experiences, boat builders switched to metal, believing it to be a superior material. And compared to those early plastic tanks, it is. But not to today's good quality, thick-walled plastic tanks. Fred, your aluminum tank is 10 years old now...you've done your best to minimize the corrosive effects of urine, and so have managed to extend the life of it considerably. But it's living on borrowed time, so I suggest you keep a very close eye on it and the area around and under it for any sign of moisture seepage, and keep a "weather nose" in its direction. 'Cuz sooner or later it has to start leaking, prob'ly on the bottom.
