Aluminum anchor connection to ss shackle
Nov 19, 2016
14
Sabre Mark III Raritan Bay, NJ
Have new light weight aluminum anchor for 21 foot sailboat.
I understand aluminum to stainless steel shackle for connecting to
anchor rode will cause galvanic corrosion.
I seek suggestions for this connection.
Thanks for help.
capta
Jun 4, 2009
4,990
Unless your anchor is going to be in the water 24/7/365, I wouldn't give it any thought at all. It's not like this is a tight connection like a screw or bolt, the shackle will move around in the anchor easily.
Jan 4, 2006
7,381
It's doubtful if you will ever see any corrosion on aluminum shank of the anchor. Although the aluminum is anodic, it has such a large surface area relative to the SS shackle, the corrosion is spread out and not noticeable.
Likes: Chief RA
Mar 26, 2011
3,808
Corsair F-24 MK I Deale, MD
Why not use a soft shackle made from line and laced to the chain?
Is this how you attach your anchor? How many days so far?
No, this is definitely not meant as sarcasm. Dyneema has been suggested before. But if you are going to suggest something new like this, walk the talk and do the testing. For example, I'm testing Dyneema leaders, but not the shackle itself, and not because I'm concerned about corrosion--as others have explained, I think that is a non-issue, based on decades of experience. One of my Fortress anchors is 25 years old.
Of course, you could use a galvanized shackle--there is very little difference in potential between Zn and Al. Why on earth use stainless?
576
Hunter 30t 9805 littlecreek
Check with anchor manufacturing spec. But I believe you need some chain on that anchor to set properly
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Whatfiero1 is right on with his assertion that you need chain on that aluminum anchor! I owned one and it was not much of an anchor. I put 25' of chain on it to make it usable as an emergency triple backup anchor and still didn't trust it to dig in. Lack of weight in an anchor presents a serious problem as far as I am concerned. As far as using a SS shackle: use it as it will not matter, but I would use galvanized to match the chain. Chief
Nov 19, 2016
14
I thank you all. Will use gal. shackle to some chain. Appreciate the inputs.
Dusty
The use of SS shackles has been questioned for good reason. SS while strong can also work harden and then catastrophically fail without warning. Plain old galvanized steel will not do that as readily.
Of course if the shackle should fail it will only do so in the dead of night in the middle of a T-storm.
Likes: pateco
Jun 21, 2004
3,035
Beneteau 343 Slidell, LA
If you decide on a galvanized shackle, do some research on Crosby shackles. They are used for heavy lifting in all industrial applications. Practical Sailor rates them highly. Many of the online chandleries have them available; just select the appropriate size for your anchor/chain. Don't forget to place some lanacote on the threads and lock wire it with SS wire.
Jan 4, 2006
7,381
You'll notice on the Fortress web page that their underwater demonstrations show the anchor just diving into a soft sandy bottom. Anything harder and it's going to skid from here to the next anchorage. Just a pretty anchor.
And the anchor battle is ON, again :poke:
Likes: Whatfiero1
Mar 26, 2011
3,808
Actually, chain can be a detriment in soft mud, dragging the shank down and inhibiting setting.
Feeling the anchor in is often the solution. There are, of course, a few bottoms fortress dislikes.
Nov 26, 2012
2,315
thinwater: I do not agree with the idea that soft mud would reduce an anchor set as it would drag the blades down with it. This could help an aluminum "danforth" more than hinder. If a Fortress aluminum anchor is any good just think how much better it would be made of 25 lbs of steel and 25' of chain! Chief
Fortress only recommends 6 feet of chain minimum with an additional 6 feet for every 25 ft of water depth.
The more expensive Fortress has adjustable mud palms which improve holding in mud.
Nov 26, 2012
2,315
I would not care what Fortress recommends for chain length for an aluminum anchor! If your hanging off of one I would recommend that you "stand watch 1800 to 0800"! Chief
Likes: NotCook
JamesG161
Feb 14, 2014
7,912
Hunter 430 Waveland, MS
:plus::plus:
The Aluminum will "re-oxidize" a protective coating when not in conductive salt water.
Jim...
capta
Jun 4, 2009
4,990
I just picked up a large Fortress anchor that still weighs less than the silly 44# Bruce I've been carrying since I bought the boat (it came with the boat). I believe the Fortress to have considerably more holding power than the Bruce (and a better tried and true design) even though it is lighter.
Efficient ground tackle is not all about the weight of the anchor, but more about matching the various pieces of the system for maximum holding power. We know someone who bought a 120# Mantus as her #2 anchor on a 40ish foot boat and 3/8" bbb chain to go with it. If conditions are bad enough to actually deploy that anchor, I doubt that the extra weight of that anchor will make any difference over a 65# anchor.
