It's doubtful if you will ever see any corrosion on aluminum shank of the anchor. Although the aluminum is anodic, it has such a large surface area relative to the SS shackle, the corrosion is spread out and not noticeable.I understand aluminum to stainless steel shackle for connecting to
anchor rode will cause galvanic corrosion.
Is this how you attach your anchor? How many days so far?Why not use a soft shackle made from line and laced to the chain?
Is that what you use?Why not use a soft shackle made from line and laced to the chain?
You'll notice on the Fortress web page that their underwater demonstrations show the anchor just diving into a soft sandy bottom. Anything harder and it's going to skid from here to the next anchorage. Just a pretty anchor.Lack of weight in an anchor presents a serious problem as far as I am concerned.
Unless your anchor is going to be in the water 24/7/365, I wouldn't give it any thought at all.
I just picked up a large Fortress anchor that still weighs less than the silly 44# Bruce I've been carrying since I bought the boat (it came with the boat). I believe the Fortress to have considerably more holding power than the Bruce (and a better tried and true design) even though it is lighter.thinwater: I do not agree with the idea that soft mud would reduce an anchor set as it would drag the blades down with it. This could help an aluminum "danforth" more than hinder. If a Fortress aluminum anchor is any good just think how much better it would be made of 25 lbs of steel and 25' of chain! Chief
