What is your budget?What's the largest/best alternator I can put on my '89 36 Catalina with the 23hp diesel? Thanks for your help.
If can certainly be noticeable.. Whenever a large amperage alternator is installed on a small diesel AUX engine their should also be a regulator cut switch which disables the regulator so you can have more power in an emergency.Maine, how about alternator drag? The numbers tell me that the drag induced by a larger alternator is not that much more than a stock one but how does it affect in practice? Have heard comments of sailors that indicate their boats seem to have lost
significant power. I would imagine the smaller the engine the larger its percentage of horsepower needed to run the alternator.
What are the risks in a regulator cut off switch?If can certainly be noticeable.. Whenever a large amperage alternator is installed on a small diesel AUX engine their should also be a regulator cut switch which disables the regulator so you can have more power in an emergency.
Usually it is not noticed under normal motoring but with batteries in bulk, while fighting a current and headwind you'd be happy you installed a regulator cut off switch at the engine panel.
I have 3 cyclinder Yanmars running 165A + alts and the owners rarely if ever need the cut switch but it is there.. I run a 160A alt on our Westerbeke but it is derated/limited to about 120-130A. I don't ever need the cut switch, even when driving the engine driven refrigeration and the LiFePO4 battery bank, but we have a 4 cylinder 40+ HP engine...
Risks? Perhaps that you forget to turn it back on....What are the risks in a regulator cut off switch?
jso
The problem with all Yanmar/Hitachi alternators, except some very old models, is that they can lead to chronic under charging and extremely slow bulk & absorption charging. Why? These alternators have a built in thermal protection system that works by lowing the target voltage point as the alt heats up.Good post. I have the Yanmar 2GMF20 with the stock 35 amp alt. I have seen upgraded alts to 100amp but that seems like overkill for my budget [both usage and wallet], and I was concerned about drag and wear and tear on the pulley system. I used to see a 65 amp alternator and thought that might be a useful upgrade. Now I don't see that unit anywhere. Is a 30 amp upgrade significant enough to warrant the expense?
Don't get me wrong but that's like asking "how long is an average piece of string". As Stu suggests you really need to know how much power you use to know what you need / want to be able to store to have a "sufficient" supply.I currently have two (2) Group 34 AGM batteries on board, I don't want to go crazy but would like a sufficient amount of power. I know this depends on a million different things but say just an average size battery bank.
I would say you are well below the "average" for a 36' boat. A group 34 AGM (likely Deka) is a 55Ah battery.Thanks for the replies everyone, I guess I would have been more correct to ask whats the highest amperage battery I can safely use. Sorry bout that. Now that use guys have answered that one, whats a moderate/good size battery bank to have? I currently have two (2) Group 34 AGM batteries on board, I don't want to go crazy but would like a sufficient amount of power. I know this depends on a million different things but say just an average size battery bank.
It depends on the engine, how much space you around it, if anyone makes a kit to fit that engine if you are not able to engineer one yourself.
We have a Hunter 356. It has a Yanmar 3GM30F , with 27 HP. I'm told above 80 Amps it is best to change the engine pulleys to use two belts or a flat belt as a single drive belt is not strong enough. I installed a 140 Amp alternator with a flat belt kit on our engine. It was an easy bolt on kit. The kit came from Electromaax. The company gives great support.
Bob
I should also add, unless you going with all AGM batteries an alternator over 80 is probably bigger than you need. We have 410 Ahr AGM bank. I have watched it suck up 153 amps from this alternator.
I found the alternator on ebay matching the # in my 3YM30 manual as the optional 85 amh alternator.
Suppose to be delivered soon
Nick
Richard, I did the install myself. It was not hard to do. I bought the kit from Electromaax.com, they supplied everything. The box above the engine is a Sterling external regulator, it has a temperature probe on the alternator and battery bank.Hey Bob
Did you do the alternator upgrade yourself. Was it an easy switch. Whats the gadget in the pic with wires attached overtop the engine. Our H356 had a newer yanmar 3ym30 engine installed by the previous owner.
Thanks
Richard
