C350 Alternators & Regulators
BillYou have a lot of research to do, so here's how I can best help you out in a short response.1. I assume you mean that the regulator is NOT putting out amps even when the batteries need a charge. Right? That's because you have an internal regulator, which is why you can't find it, it's strapped onto the back of the alternator itself. It is NOT external. And that's why you are not getting much out of it, because it is an automotive regulator.2. You should, if you haven't yet, buy Nigel Calder's Boatowner's Manual. Best $50 you or the rest of the new C350 group can do.3. If you're worried about being on the hook on your trip, you need to do an energy budget, and then find out if you have enough house bank capacity. If you have a stock C350, you most likely do not (maybe two batteries, maybe three with one as a starting battery). The more electricity you use, the more house bank capacity you need to reduce engine running time. Your stock alternator won't do it for you on the trip I understand you are contmplating without long engine runnign time {see item 1 above}. (References are www.jackrabbitmarine.com, amplepower.com, and th West Marine Advisors - www.westmarineproducts.com) They cover a lot of this basic stuff on their websites. Do google searches on batteries, alternators, regulators, there's SOOO much information out there.4. I've linked you to a long writeup in our C34 message board that may help get you started to answer your questions. It includes a link to the C36 'site about the very issue you are talking about.5. Try doing a Forum Archive Search on "Nigel Calder" or "calder." I'll bet you get a lot of hits and explanations of issues that you are dealing with.I wish you the best of luck on your trip, and hope you have the time to get your system in the condition that is appropriate for the use intended.You have three basic choices:The easiest and shortest answer, in a limited time, would be to drastically increase your house bank capacity. Or, you could get your stock alternator adjusted (rewired) to work with an external regulator (see the link, it has a link to another site by the C36 folks) and buy the external regulatorOr you could buy a new alternator and external regulator (packaged by Balmmar, Ample, JackRabbit, etc.). Don't exceed the recommended alternator size for the size of your engine, to avoid sideloading and overloading the internal engine bearings. That'll be a bit o'work to do in a few weeks, but could be done in a day or two by a knowledgeable person once the parts and wires, etc. are assembled. Good luck, have a great trip and keep reading. You have a great boat and we met Mark Kohler and his wife here on SF Bay when they'd just purchased their new boat.All the best,StuPS - sorry it got so long.
