After about only 10 hours of use on my new 60 Amp alternator for my Yanmar 3GM I noticed that the voltage (via my Victron Battery Monitor) shot up to approx. 15.3 volts at idle! I was running the engine for about 25 minutes at varying RPMs and was monitoring the voltage and amps produced. I was loud near the engine but as I was slowing the engine rpms and letting it idle I noticed my alarm was going off on my battery monitor that the voltage was high. I immediately shut the engine down but was limited on time to do much trouble shooting.
What is the maximum output in volts of an internally regulated alternator?
Also, could this be a symptom of a bad ground to the alternator? Bad diode?
FYI: The batteries are flooded; I have a house bank of approx 260 amp hours and a reserve back of 90 amp hours. The banks are connected only through a Blue Seas Automatic Charging Relay when conditions allow.
